Hi, my name is Suresh. Iam at present working on the AT91R40008 microcontroller. Iam using the Keil compiler for the firmware coding. I want to access the ARM7DMI core registers. i mean, i want to take the results to my hyperterminal. Iam able to display the microcontroller peripheral Registers (like EBI_, PIO_, SF_, USART_, etc). Now i also want to access ARM core Registers "R1 to R14", through my hyperterminal. Iam not able to include assembly code inbetween my C source code. In technical support, given by Keil. they suggest to try the #pragma to generate my *.SRC file. but iam not able to generate the *.SRC file in uVISION3. can anyone guide me how to access the ARM core registers in my C source code. That is, i need to include some assembly code inbetween my main *.C source file. If that is happening, thn i can try out for the Core Registers...! Thanks in Advance..! Waiting for your earliest reply...! regards Suresh
Which Compiler are you using Keil ARM, GNU, or ADS?
Thanks for ur reply Iam using Keil ARM compiler. can u help me out,.,,,,! Regards Suresh
