I want to use the external interupt pin 0. So I configured the Port 1 like this : // 3 IRQ : Input Only.
P1M1 = 0X7E; P1M2 = 0x81;
interupt pin 0. ... Port 1 .... P1M1 = 0X7E; P1M2 = 0x81; ... greied ???? your message makes absolutely no sense. Maybe it would, if you mentined which derivative you are using. Erik
Excuse me ! I forgot to say : I'm developing on uVision for the Philips P89LPC932. I wanted to write : I want to use the external interupt INT0 on pin P1.3. ... While debugging, you usually can change the I/O port mode and it's value. But in my case, the P1.2 and P1.3 port mode checkboxes are inhibited. That's my problem. Usually Interupt pins are supposed to be inputs. Thanks again.
