Help! I am having problems getting the OCDS/JTAG connection to work with the infineon XC16Board using the wiggler (parallel port cable) No matter what I do, I always get the message: "Error: Flash download failed - Target DLL cancelled" Anyone could help? Thanks
Does your compiler need a "Dongle" (hardware key)? Certainly, the C51 dongle access causes this problem when using a Wiggler with the Triscend E5!
Yes, I use the dongle in order to use the PK166. you mean the dongle may affect the connection. If I cant use dongle, how to run the Keil program? Thanks!
Buy a PCI card with a parallel port? - mike
"you mean the dongle may affect the connection." I am absolutely certain - I have seen it happen! :-( If you have a dongle, you must have a full licensed product - so you should speak to Keil support direct about this. You should be able to negotiate a solution. Meanwhile, you might like to take a look at the section "Dongle and Parallel Port Communication Issues" in Triscend' FastChip software release note: ftp.triscend.com/.../release_note.htm Section (2.4) describes a workaround that I found to work for the E5 and dongled PK51 - it may or may not help you with your PK166... (Note that I have no affiliation with Keil or Triscend; views expressed are my own)
"Buy a PCI card with a parallel port?" Then read http://www.keil.com/support/docs/1788.htm
Hi , there is no problem to use OCDS with Infineon Starterboard. I tested with Win2k, WinXP and Win98 and a colleaque under WINNT. The dongle has no influence (concerning OCDS). I test the on-board wiggler and directly with ULINK. First you have to check that JP5 is set to enable the onboard wiggler. Than you should shut off all other parallel port drivers , if there any. It costs me approx. 2 days to find out was happen. Than you have correct to set the dip switches on board. ( Here mainly DIP106 ). If your debugger settings in µVision are right so no problems should occur. May be that there are problems under XP - there I test only the ULINK. Some board was delivered out with unsoldered contacts to JTAG - so check your board concerning this one. Stefan
