we want to be able to change processor clock in a running CMSIS RTOS application.
As we see, we can only statically configure RTOS via RTX_CONF_CM.c (OS_CLOCK). In addition all variables using OS_CLOCK are defined const in RTX_CM_lib.h.
Is there a way to change processor clock via SystemCoreClockUpdate() so that timer tick of RTOS is modified accordingly ? So that e.g. osDelay() will always wait same time amount.
Best regards Juergen
You are referring to RTX4 (based on CMSIS-RTOS API) which assumes that the processor clock does not change dynamically.
You should consider upgrading to RTX5. You may continue using CMSIS-RTOS API or migrate to CMSIS-RTOS2 API. Take a look at the migration guide: http://www.keil.com/pack/doc/CMSIS/RTOS2/html/os2Migration.html
When using RTX5 and the processor clock changes you just need to setup the SysTick LOAD register correctly after calling SystemCoreClockUpdate().
Somehing like this:
// freq: Kernel Tick Frequency defined in RTX_Config.h (typically 1000) SysTick->LOAD = (SystemCoreClock / freq) - 1U;
