uVision 5 lag a lot and freeze with text completition and space+ctrl
Hi
I'm using uVision 5 on a MSI PS42 laptop with Windows 10 64bit, core i7-8550u, 16Gb of ram. When I wrote my code, the ctrl+space shortcut and all the text-Completition functionality made my computer lags a lot and after few seconds freeze it.
I have to force shutdown or wait more than 10 minutes for the text completition to appear normally.
If I try to recall again the text completition the lag and freeze's problems reappears.
At the moment disable all the text completition functionality from the options is the only "workaround" I can use right now.
Same problem with uVision4. All the rest of the program seems to work well.
Someone that have the same problem or can help??
Cataldo
