I want to use HAL & RTX together in a project based on stm32f4. I made changes that u see at this link: www.keil.com/.../cubemx__r_t_x.html But still it does not work... What is the problem??
That's like saying, "My car won't go - what's wrong with it?"
Nobody can answer that - clearly, there is simply not enough information!
So what have you done to debug the problem(s) ?
Before trying to use RTX and the ST HAL together, have you been able to successfully make separate projects using each one independently?
Tryin to learn 3 new things all at once is vastly more difficult that trying to learn one new thing at a time ...
Yes. I have run them seperately without any problem. But when i want to use hal & RTX together it doesnt work.
For debugging, i used keil debugger. i guess problem is one of this issues: clock, sys tick, svc handler...
So investigate those possibilities!
You say you have working examples - so look at how they work, and see what's different in the one that doesn't.
Debugging is a basic skill for programming (and, in fact, any type of development):
www.avrfreaks.net/.../2418156
