We are using arm7 (lpc2148) microcontroller. We performed Led blinking code.(keil uvision 4 compiler) Code is not showing any error or warnings. After debugging ,we are unable to run the code. Though i got the output once.Then again we were facing same problems Please provide the solution ASAP.
Sorry, you'll need to use the debugger and step and review the executing code. If it doesn't get to main(), uncheck the "Run to main()" option, and start at the Reset Handler or startup code.
Lack of errors/warnings means there are not syntax issues with the code, not an indication it is functional.
You'll need to check your board, connections and configurations. Unfortunately zero details on board, pins and code provided.
www.segredosdosonho.com.br/index.asp
<a href="">www.segredosdosonho.com.br/"> Web site</a>
