Hi all,
Recently, I have problems compiling with Keil. I'm using ARM Compiler V6.7 and I get the following error:
ArmClang.exe: error: Failed to check out a license.Keil Licensing error: No TOOLS.ini file found ArmClang.exe: note: Check that your license details are correct in the License Management dialog of MDK. Additional information is available at: If you need further help, provide this complete error report to your supplier or license.support@arm.com. - ARMLMD_LICENSE_FILE: unset - LM_LICENSE_FILE: unset - ARM_TOOL_VARIANT: unset - ARM_PRODUCT_PATH: unset - Product location: C:\Keil_v5\ARM\sw\mappings - Toolchain location: C:\Keil_v5\ARM\ARMCLANG\Bin - Selected tool variant: mdk_cm_std ArmClang.exe: note: - Checkout feature: LIC0=JA...-.....-..... - Feature version: 5.0201703 - Keil error code: 1 Product: MDK-ARM Essential 5.24 Component: ARM Compiler 6.7 Tool: armclang [5c9efc00]
I'm using the following version of Keil:
Toolchaing: MDK-ARM Essential Version: 5.24.1 Toolchain Path: C:\Keil_v5\ARM\ARMCLANG\Bin C Compiler: ArmClang.exe V6.7 Assembler: Armasm.exe V6.7 Linker/Locator: ArmLink.exe V6.7 Library Manager: ArmAr.exe V6.7 Library Manager: ArmAr.exe V6.7 Hex Converter: FromElf.exe V6.7 CPU DLL: SARMCM3.DLL V5.24.1 Dialog DLL: DCM.DLL V1.16.0.0 Target DLL: STLink\ST-LINKIII-KEIL_SWO.ll V3.0.1.0 DialogDLL: TCM.DLL V1.32.0.0
Someone knows why I have this error? How can I solve it?
I haven't changed any configuration and the error appears suddenly. These problems only happen with ARM Compiler V6.7. However, if I use ARM Compiler V5, error doesn't happen.
Any help will be appreciated. Thank you in advance.
Luis
Try this http://www.keil.com/support/docs/3961.htm
I too get the following error but the resolution does not seem to apply (i.e. the app note). *** Using Compiler 'V6.9', folder: 'C:\Keil_v5\ARM\ARMCLANG\Bin' Build target 'HulkHW_1Simulator' ArmClang.exe: error: Failed to check out a license.Keil Licensing error: No TOOLS.ini file found ArmClang.exe: note: Check that your license details are correct in the License Management dialog of MDK. Additional information is available at: www.keil.com/.../license_management.htm If you need further help, provide this complete error report to your supplier or license.support@arm.com. - ARMLMD_LICENSE_FILE: unset - LM_LICENSE_FILE: unset - ARM_TOOL_VARIANT: unset - ARM_PRODUCT_PATH: unset - Product location: C:\Keil_v5\ARM\sw\mappings - Toolchain location: C:\Keil_v5\ARM\ARMCLANG\Bin - Selected tool variant: mdk_pro ArmClang.exe: note: - Checkout feature: LIC0=TA...-.....-..... - Feature version: 5.0201710 - Keil error code: 1 Product: MDK Professional 5.25 Component: ARM Compiler 6.9 Tool: armclang [5ced1d00]
