I am trying to setup UART1 have done the setting for GPIO and UART both. The data which I transmit over UART is coming to UART_DR (I am using Keil and CMSIS core Library to code it and in simulation window I can read the data in UART_DR) but I am not getting anything on UART1 window or serial console in Keil debugger.
Here are my code snippets for configuring GPIO and UART along with main function.
#define U1RX (1<<4) #define U1TX (1<<5) #define PORTC (1<<2)
#define TXFF (1<<5) #define RXFE (1<<4) #define UART1EN (1<<0)
void GPIOC_Init() { SYSCTL->RCGCGPIO |= PORTC ; //Enable PORTC GPIOC->AFSEL |= (U1TX | U1RX); // Set Pin Functions to Alternate Functions GPIOC->PCTL = (GPIOC->PCTL & 0xFF00FFFF) + 0x00220000; //Set Alternate Functions to UART1 (PMC5 = 0x0010 and PMC4 = 0x0010) GPIOC->DEN |= (U1TX | U1RX); //Enable Digital functionality to UART Pins (PC4 = 1 and PC5 = 1) GPIOC->AMSEL &= ~(U1TX |U1RX);
void UART_Init() { SYSCTL->RCGCUART = 0x02; // Enable UART1 UART1->CTL |=~UART1EN ; //Disable UART before configuration
UART1->IBRD = 0x08; UART1->FBRD = 0x2C; // Baud Clock is 16MHz and BR = 115200 UART1->LCRH = 0x60; // 8N1, FEN disabled UART1->CC = 0x5; // Select clock source as PIOSC System Clock UART1->CTL |= UART1EN; // Enable UART
void UART_Send(uint8_t data) { while((UART1->FR & TXFF)){}; // Wait till TX FIFO is Full
UART1->DR = data; }
int main() { uint8_t data[] = {"TM4C123GH6PM UART TX DEMO"}; uint8_t i, ch;
GPIOC_Init(); UART_Init();
for (i = 0; data[i] != '\0'; i++) UART_Send(data[i]);
while(1); }
I also have disabled clock setup in system_TM4C123.c file which is being used at startup. So after doing all this I am not understanding why m I not getting data on console while I get it in UART_DR?
Real hardware? http://www.keil.com/dd/chip/6015.htm Do you have any code establishing output to the debug console? via ITM/SWV? Do you have a terminal or VCP connected to the output pin of the UART? I would expect ITM_SendChar() to work in the simulator, based on the chip level support specified the UART not so much.
I tried once only to connect to real hardware and it did not work.Then I thought I should get it working on simulator then try on real hardware. I also forgot to mention that I am disabling clock settings in system_TM4C123.c file by setting "#define CLOCK_SETUP 0". I hope this might not have huge impact.
I had to do this as the control was not coming out of " while ((SYSCTL->RIS & (1UL<<6)) != (1UL<<6));" statement which checks if PLL is locked or not. I understood from this is that PLL was not getting locked.
