Dear friends on the internet,
Please note that I am very new to linux (Ubuntu)
I want to run Keil uVisions5 on my computer. Thus far I have been able to install it through wine. But when I try to launch from the desktop shortcut I get the following message:
"Cannot read C:\Keil_v5\TOOLS.INI
uVision is unusable without a valid TOOLS.INI file. Please reinstall your toolchain"
I have checked and TOOLS.INI is certainly not missing. How do I proceed from here? Is it even possible to run the program through wine? If you have any ideas, let me know!
Many thanks in advance and kind regards!
and is it in the specified location?
can you open it with a text editor?
Yes it is in the specified location and I can open it with notepad
Do you have a 2nd Keil toolchain installed at C:\Keil_v5 ? If yes, use different folders for each product instead.
Beside - also assure that you have administrative privileges on the system/installation folder.
Hello Bent,
Have you seen this article? It might be useful.
http://www.keil.com/support/docs/1456.htm
