github.com/.../rtx_os.h
/// OS Runtime Information structure typedef struct { const char *os_id; ///< OS Identification uint32_t version; ///< OS Version struct { ///< Kernel Info uint8_t state; ///< State volatile uint8_t blocked; ///< Blocked uint8_t pendSV; ///< Pending SV uint8_t reserved; uint32_t tick; ///< Tick counter } kernel; int32_t tick_irqn; ///< Tick Timer IRQ Number struct { ///< Thread Info struct { ///< Thread Run Info osRtxThread_t *curr; ///< Current running Thread osRtxThread_t *next; ///< Next Thread to Run } run; osRtxObject_t ready; ///< Ready List Object osRtxThread_t *idle; ///< Idle Thread osRtxThread_t *delay_list; ///< Delay List osRtxThread_t *wait_list; ///< Wait List (no Timeout) osRtxThread_t *terminate_list; ///< Terminate Thread List struct { ///< Thread Round Robin Info osRtxThread_t *thread; ///< Round Robin Thread uint32_t tick; ///< Round Robin Time Tick uint32_t timeout; ///< Round Robin Timeout } robin; } thread; struct { ///< Timer Info osRtxTimer_t *list; ///< Active Timer List osRtxThread_t *thread; ///< Timer Thread osRtxMessageQueue_t *mq; ///< Timer Message Queue void (*tick)(void); ///< Timer Tick Function } timer; struct { ///< ISR Post Processing Queue uint16_t max; ///< Maximum Items uint16_t cnt; ///< Item Count uint16_t in; ///< Incoming Item Index uint16_t out; ///< Outgoing Item Index void **data; ///< Queue Data } isr_queue; struct { ///< ISR Post Processing functions void (*thread)(osRtxThread_t*); ///< Thread Post Processing function void (*event_flags)(osRtxEventFlags_t*); ///< Event Flags Post Processing function void (*semaphore)(osRtxSemaphore_t*); ///< Semaphore Post Processing function void (*memory_pool)(osRtxMemoryPool_t*); ///< Memory Pool Post Processing function void (*message)(osRtxMessage_t*); ///< Message Post Processing function } post_process; struct { ///< Memory Pools (Variable Block Size) void *stack; ///< Stack Memory void *mp_data; ///< Memory Pool Data Memory void *mq_data; ///< Message Queue Data Memory void *common; ///< Common Memory } mem; struct { ///< Memory Pools (Fixed Block Size) osRtxMpInfo_t *stack; ///< Stack for Threads osRtxMpInfo_t *thread; ///< Thread Control Blocks osRtxMpInfo_t *timer; ///< Timer Control Blocks osRtxMpInfo_t *event_flags; ///< Event Flags Control Blocks osRtxMpInfo_t *mutex; ///< Mutex Control Blocks osRtxMpInfo_t *semaphore; ///< Semaphore Control Blocks osRtxMpInfo_t *memory_pool; ///< Memory Pool Control Blocks osRtxMpInfo_t *message_queue; ///< Message Queue Control Blocks } mpi; } osRtxInfo_t;
github.com/.../issues
This is related to: http://www.keil.com/forum/62539/
Relates to original post (which is read-only): http://www.keil.com/forum/62539
Solution is provided here: github.com/.../296
