Dear, I program in keil arm and use c++. I receive error: C:\Keil\ARM\ARMCC\Bin\..\include\vector.CC(120): error: #349: no operator "=" matches these operands operand types are: std::pair<CGXByteBuffer, CGXByteBuffer> = const std::pair<CGXByteBuffer, CGXByteBuffer> *__it = __x;
That warns for code:
template <class _TypeT, class _Allocator> void vector<_TypeT,_Allocator>::_C_insert_aux ( iterator __it, const_reference __x) { if (capacity () > size ()) { // avoid dereferencing end () by incrementing _C_finish first pointer __old_end = _C_finish; ++_C_finish; _TRY { _RWSTD_VALUE_ALLOC(_C_value_alloc_type, construct (__old_end, *(__old_end - difference_type (1)))); } _CATCH (...) { _RWSTD_VALUE_ALLOC(_C_value_alloc_type, destroy(__old_end)); --_C_finish; _RETHROW; } copy_backward (__it, _C_make_iter (__old_end - difference_type (1)) , _C_make_iter (__old_end)); *__it = __x; } else { // more memory needed size_t __new_capacity = _RW::__rw_new_capacity(size(),this); pointer __start = _RWSTD_VALUE_ALLOC(_C_value_alloc_type, allocate(__new_capacity, (void*)_C_start)); _TRY { uninitialized_copy(begin(), __it, __start, _RWSTD_VALUE_ALLOC_CAST (*this)); _RWSTD_VALUE_ALLOC(_C_value_alloc_type, construct((__start + (__it - begin())), __x)); uninitialized_copy(__it, end(), __start + (__it - begin()) + difference_type (1), _RWSTD_VALUE_ALLOC_CAST (*this)); } _CATCH (...) { _C_destroy (_C_make_iter (__start), _C_make_iter (__start + __new_capacity)); _RWSTD_VALUE_ALLOC(_C_value_alloc_type, deallocate (__start,__new_capacity)); _RETHROW; } // compute size before deallocating size_type __size = size (); _C_destroy (begin(), end()); // invalidates all iterators into '*this' _RWSTD_VALUE_ALLOC(_C_value_alloc_type, deallocate(_C_start, capacity ())); _C_start = __start; _C_finish = __start + __size + difference_type (1); _C_end_of_storage = __start + __new_capacity; } }
Please share your solution!
