I have task waiting on event flags that are triggered from ISR base on TX buffer empty or RX frame received. But I am observing RTOS locking up after a random period ranging from 5 min to few hours. I am not able to figure out why RTOS would be locking up. Using the debugger I can see SysTickTimer not increment, tasks don't switch, no hard faults but ISRs (timers & uarts) triggering.
If I do not receive any data on this uart, no lockups ever. Sending is very busy but data received is very tiny (50-100 bytes/5sec). Uart runs @1MBit baudrate. I have narrow down issue to receiving any data on this uart.
I will appreciate any insight on this issue. Here is the part of the code:
/** * */ #ifdef USART2 void USART2_IRQHandler(void) { static uint8_t ChB; if(USART_GetITStatus(USART2, USART_IT_TXE) != RESET) { if (CBUF_Getch(&UsartBOutCBuf, &ChB)) { USART_SendData(USART2, ChB); } else { // Uart TX buffer empty, Set event for task to check if endpoints have data to be send. isr_evt_set(EVT_FLG_SMPP, TASKID_SMPP); USART_ITConfig(USART2, USART_IT_TXE, DISABLE); } } if((USART_GetITStatus(USART2, USART_IT_RXNE) != RESET) || (USART_GetITStatus(USART2, USART_IT_ORE) != RESET)) { ChB = USART_ReceiveData(USART2); CBUF_Putch(&UsartBInCBuf, ChB); if (1 == SMPP_CheckFrame(ChB)) { // SMPP frame received, Set event for task to read frame, parse and write data to endpoint. isr_evt_set(EVT_FLG_SMPP, TASKID_SMPP); } } } #endif /** * */ __task void task_smpp(void) { OS_RESULT result; uint16_t myTaskId; const uint16_t strLen = 64; uint8_t str[strLen]; int8_t byte; uint16_t indx; myTaskId = TASKID_SMPP; for (;;) { TASKCNT_SMPP++; result = os_evt_wait_or (EVT_FLG_SMPP, 1000); if (result == OS_R_TMO) { //postLog ( LogTag_SMPP, "In task_smpp - OS_R_TMO \r\n" ); } else { // Event received //postLog ( LogTag_SMPP, "In task_smpp - OS_R_EVT \r\n" ); SMPP_WriteFrame(); SMPP_ReadFrame(); } } }
