Hi
I'm using DMA with ADC1 channels 12 & 16. ADC1 Channel_16 is the core temperature. The code below works ie when the DMA flags the DMA_Buffer contains 800 samples, 400 for Channel_12 400 for Channel_16 However I only need a 4 samples for Channel_16 Is there a way to configure the DMA to retrieve 400 samples on Channel_12 and 4 samples on Channel_16.
Thanks Liam
#define BUFF_SIZE 800 uint32_t DMA_Buffer[BUFF_SIZE];
void ConfigConductivityADC (void) { ADC_InitTypeDef ADC_InitStructure; RCC_ADCCLKConfig(RCC_PCLK2_Div6); ADC_DeInit(ADC1); // ADC1 configuration ADC_InitStructure.ADC_Mode= ADC_Mode_RegSimult; ADC_InitStructure.ADC_ScanConvMode= ENABLE; ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T3_TRGO; ADC_InitStructure.ADC_DataAlign= ADC_DataAlign_Right; ADC_InitStructure.ADC_NbrOfChannel= 2; ADC_Init(ADC1, &ADC_InitStructure); ADC_TempSensorVrefintCmd(ENABLE); ADC_DMACmd(ADC1, ENABLE); ADC_RegularChannelConfig(ADC1, ADC_Channel_12, 1, ADC_SampleTime_239Cycles5); ADC_RegularChannelConfig(ADC1, ADC_Channel_16, 2, ADC_SampleTime_239Cycles5); ADC_ExternalTrigConvCmd(ADC1, ENABLE); ADC_Cmd(ADC1, ENABLE); ADC_ResetCalibration(ADC1); while(ADC_GetResetCalibrationStatus(ADC1)); ADC_StartCalibration(ADC1); while(ADC_GetCalibrationStatus(ADC1)); }
void ConfigConductivityDMA(void) { DMA_InitTypeDef DMA_InitStructure; /* DMA1 channel1 configuration ----------------------------------------------*/ DMA_DeInit(DMA1_Channel1); DMA_InitStructure.DMA_PeripheralBaseAddr=ADC1_DR_Address; DMA_InitStructure.DMA_MemoryBaseAddr=(uint32_t)DMA_Buffer; DMA_InitStructure.DMA_DIR=DMA_DIR_PeripheralSRC; DMA_InitStructure.DMA_BufferSize=BUFF_SIZE; DMA_InitStructure.DMA_PeripheralInc=DMA_PeripheralInc_Disable; DMA_InitStructure.DMA_MemoryInc=DMA_MemoryInc_Enable; DMA_InitStructure.DMA_PeripheralDataSize=DMA_PeripheralDataSize_Word; DMA_InitStructure.DMA_MemoryDataSize=DMA_MemoryDataSize_Word; DMA_InitStructure.DMA_Mode=DMA_Mode_Circular; DMA_InitStructure.DMA_Priority=DMA_Priority_High; DMA_InitStructure.DMA_M2M=DMA_M2M_Disable; DMA_Init(DMA1_Channel1, &DMA_InitStructure); }
That would depend entirely on the actual chip that you are using - it has nothing to do with Keil.
You need to study the chip's documentation for details of what it can & cannot do - and how to configure it.
You should visit the particular chip manufacturer's website for further support.
Yes I should have given the device, it's a STM32F103ZE
I'll try the ST forum
