Hi, i am new to this forum,i am working for LPC1768 tcpnet examples,i am able to load telnet_server example and HTTP_Demo example independent and working properly , i need both telnet_server example and HTTP_Demo example should work at a time. if i modify and merge the both examples will it work? is it possible?
thanks®ards jayaganesh
Yes and yes.
You would of course have to ensure you merge them so they do work correctly together.
hi Terry Kotter thanks for your quick reply,if i do changes NET_Config.c both the server enable is 1 TNET_ENABLE 1 and HTTP_ENABLE 1 its not working,kindly guide me on this..
Time to get debugging, then!
www.avrfreaks.net/.../2173461
