Hello, I am currently having problems running my code on Keil. I have to press the run button(F5) for every line of code. Furthermore, if I make a function call, once the debugger reaches the function, (i am using function from CMSIS-DSP library for example) I must also click the run button for each line of code in the function as well.
I have a feeling that it is due to the error 65 message I receive every time I click the run button in the command window. I tried following what the Keil site suggests about the error message, ie mapping the parts of memory where i want read/write/execute access, but when I recompile and run the debugger again, the mappings I just did are gone and I get the error message again.
Any help would we appreciated.
WHAT are you debugging, the debug for '51, '16x and ARM is NOT the same.
why oh why do so many think it should be a secret which device they use
The device is an arm cortex: arm_cortexM4, STM32F4 Series. My apologies for not specifying. Please let me know if you would like me to include more information.
So set up an Initialization File with the settings you require:
http://www.keil.com/support/man/docs/uv4/uv4_dg_debug.htm
Error 65 is classically a result of using the SIMULATOR and not the real device with a debugger, and where the device is NOT supported by the simulator
