Hi, I am new to Keil software. I am using STM32F4O7 discovery board. I want to run my code and then get variable values from the memory window so that I can plot in Matlab. For this, first, I want to run a few examples which are already present. So I took one example from module-13 and then build it and then downloaded it onto the hardware. Then I started the debugging session. Then I ran the code and stopped it in between. I am not able to see any variables in the memory window, watch window.
Can I open the file from any location initially or should I save it some folders? Is this execution flow correct? Is there any good material for beginners readily available on the internet?
>>Is there any good material for beginners readily available on the internet? What does Mr Google say? There's probably videos too, they'd be on YouTube, and training seminars.
>>So I took one example from module-13.. Citation, what module from where?
There are CMSIS-PACK examples for the STM32F407 family
Open the Pack installer, C:\Keil_v5\uv4\PackInstaller.exe
- On the top left of the window, Click on the "Boards: tab. - For "Search", type "STM32F4-" - the list below gets filtered. - Select the "STM32F4-Discovery" board (entry with a green icon) from the list below – on the right side of the dialog updates with Software Packs relevant to this device - For "Packs", install the Keil:STM32f4xx_DFP pack (if necessary) - On the top right of the screen, select the yellow "Examples" tab. - On the "CMSIS-RTOS Blinky (STM32F4-Discovery)" row, click the "copy" button - a dialog pops up. - Pick a directory, click both the check boxes, and press OK - a new Keil µVision session opens with the example. - Build the project, Connect a USB cable to the board and start the debugger
See also - the Getting Started guide at http://www.keil.com/gsg - Learning page http://www.keil.com/learn - Creating applications at http://www.keil.com/support/man/docs/uv4/uv4_ca_packinstaller.htm - Our Lab for the STM32F4 Discovery Board http://www.keil.com/appnotes/docs/apnt_230.asp
- You can watch a video using a simlilar device here: www.youtube.com/.../Qwl3kzpG2ug
Thank you.
Yes - vast amounts of it!
But, again, this sounds like a school assignment - so your first point of contact should be your teacher, and your course notes, and your course reading list.
Specifically for the STM32, ST themselves have a load of stuff:
www.st.com/.../stm32-education.html
www.st.com/.../stm32-step-by-step.html
www.st.com/.../stm32-moocs.html
" href= "http://www.youtube.com/user/STonlineMedia">www.youtube.com/.../STonlineMedia
And, again, from Keil:
www2.keil.com/.../learn
http://www.keil.com/books/
And some general 'C' learning & reference resources:
blog.antronics.co.uk/.../
