Hello Everyone, Having a nagging issue that appears to be limited to my desktop (uVision5.22), my laptop (uVision5.18) flashes the MCU perfectly fine.
Board: LPC1768 Firmware: 141212 (most current) Serial Driver: mbedWinSerial_16466 (updated w/ board) Algorithm: LPC17xx IAP 512kB Flash Address Range: 00000000H-0007FFFFH Xtal: 12 MHz Sources: startup_LPC17xx.s, system_LPC17xx.c Debug: CMSIS_DAP Debugger RAM: 0x10000000, Size: 0x0FE0 Build: "0 Error(s), 0 Warning(s)" uVision5: Version 22
Error: "PDSC: Cannot recover from reset", "Flash Download Failed - Target DLL has been cancelled"
I've been reading through the forums and searching else where online, but not finding many suggestions. Was comparing tools.ini files between desktop and laptop versions, but no luck.
Open to suggestions or thoughts if you have them, it would be much appreciated.
