Set standard lib memory address
I need to set the standard lib memory address. I have the default value of options for target on external memory. Setting the options for some groups I can load startup on internal rom and others in ram I can load and run them in ram and have an image in external flash.
The standard libs are put in external flash and this cause me hard fault on printf.
Have you a solution?
  • I have never ever needed to set any standard lib memory address. And I don't think you need either.
    When the linker produces a binary, it computes all target addresses that needs to be adjusted based on where the different code blocks are stored.
    You do not (!) want to create an application that depends on the library functionality having been compiled months earlier and placed in the flash. Any changes in version between compilers or if you build your application with a newer version of the compiler etc would invalidate any assumption that it's safe to call the individual functions already stored in that other flash block.
    Unless you are a very advanced developers with a huge amount of experience, you really should make your application binary 100% self-contained. So the boot loader downloads an opaque binary blob and places at a predefined target address in flash without understanding the actual logic of the application. And the application after being started manages itself all alone without any assumptions on binary functions already behing stored at magic addresses in the device.
    Next thing is that it should be ok to have your code in any memory address range that the processor actually supports for code execution. If your program fails when a function is in a specific memory region, then it's time to start debugging to find out what assumptions you have made that aren't correct.
    Have you verified your stack sizes? That all RAM gets properly initialized? That all memory controllers for external memory is initialized before the first access to external memory regions?
    Obviously, if there is a bug in the program, then moving code or moving variables may change the behaviour of the program. Sometimes, some rearranging may make the bug stop producing any bad effects. But moving code/variables is best done after you have found and fixed the bug - just to make sure that same bug doesn't show up again later but giving some other unexpected result.
  • I have no idea what you are doing, with what chip, and what board/configuration.
    You have to configure and initialize external memory and buses BEFORE you can use them, this usually needs to get done in startup code YOU supply, that brings an understanding of YOUR hardware as you've created it. In the CMSIS model this is often done in routines called from SystemInit() and done prior to the C run time initializing the statics.
    You can direct functions and objects to specific memory regions by using a Scatter File which is a more comprehensive/complex description of your memory map/expectations than the simple GUI IROM/IRAM settings.
  • Maybe the first message was not so clear.
    Purpose:
    Execute code in external ram with exception of startup and system init code executed in internal rom.
    Code loaded from external flash (EROM).
    In this way I can configure the bus, then use a memory larger than micro memory to load the code in ram and then the cpu can execute the code from the ram.
    In the gui I can configure default RO with the EROM,
    then the startup with IROM
    and finally ERAM and IRAM with default R/W.
    Then I can configure startup and system init to be coded in IROM.
    Result:
    I reach the result with this scatter file
    LR_IROM1 0x08000000 0x00200000 { ; load region size_region ER_IROM1 0x08000000 0x00200000 { ; load address = execution address *.o (RESET, +First) *(InRoot$$Sections) system_stm32f7xx.o (+RO) startup_stm32f767xx.o (+RO) }
    LR_ROM1 0x64000000 0x01000000 { RW_RAM1 0xC0000000 0x02000000 { ; RW data .ANY (+RW +ZI +RO) } RW_IRAM1 0x20020000 0x00060000 { system_stm32f7xx.o (+ZI +RW) startup_stm32f767xx.o (+ZI +RW) .ANY (+RW +ZI) }
    } Is it possible to reach the same result with the uVision GUI?
