What is the expected timing of events concerning CMSIS I2C events for a Write Read transaction? I am currently using a STM32F407 MCU with the CMSIS library and am surprised by the timing of when the events I an seeing.
Below is a listing of what I see with the latest CMSIS lib from ST/ARM which is installed through the Packs installer in Keil uVision. The library header contains:
* Copyright (c) 2013-2016 ARM Ltd. * $Date: 30. May 2016 * $Revision: V2.6 * Driver: Driver_I2C1, Driver_I2C2, Driver_I2C3 * Configured: via RTE_Device.h configuration file * Project: I2C Driver for ST STM32F4xx
DUT is the STM32F407 and the I2C driver on the DUT is configured as a slave. An external master I2C issues a WriteRead type of command using the restart condition. A single byte is written to the DUT and 4 bytes are read from it. The order of I2C bus events as observed in a test with the DUT:
1) Master issues [START] condition. 2) Master writes DUT address (7-bit) with write bit set. 3) DUT issues ACK - CMSIS lib in the DUT issues the "ARM_I2C_EVENT_SLAVE_RECEIVE" event. 4) Master transmits a single byte. 5) DUT issues ACK 6) Master issues [RESTART] condition 7) Master sends out DUT address with read bit set. 8) DUT issues ACK - CMSIS driver in DUT issues "ARM_I2C_EVENT_TRANSFER_DONE" event. 9) DUT transmits 3 bytes and master issues ACK for each. - CMSIS driver in DUT issues "ARM_I2C_EVENT_SLAVE_TRANSMIT". 10) DUT transmits 1 byte and master issues NACK (in accordance with the I2C spec). - CMSIS driver in DUT issues "ARM_I2C_EVENT_TRANSFER_DONE". 11) Master issues [STOP]
What I expect is the following (differences marked with ***):
1) Master issues [START] condition. 2) Master writes DUT address (7-bit) with write bit set. 3) DUT issues ACK - CMSIS lib in the DUT issues the "ARM_I2C_EVENT_SLAVE_RECEIVE" event. 4) Master transmits a single byte. 5) DUT issues ACK 6) Master issues [RESTART] condition *** CMSIS driver in DUT issues "ARM_I2C_EVENT_TRANSFER_DONE" event. 7) Master sends out DUT address with read bit set. 8) DUT issues ACK *** CMSIS driver in DUT issues "ARM_I2C_EVENT_SLAVE_TRANSMIT". 9) DUT transmits 3 bytes and master issues ACK for each. 10) DUT transmits 1 byte and master issues NACK (in accordance with the I2C spec). - CMSIS driver in DUT issues "ARM_I2C_EVENT_TRANSFER_DONE". 11) Master issues [STOP]
What is the correct way? ALso, is there a document which I can reference which links the bus-events to the ARM_I2C_EVENT_X? I find the CMSIS Doxygen docs from ARM lacking in description of timing events like this. A diagram would be hugely beneficial.
Cheers, Dirk
What you expect is the correct functionality. I suggest that you contact support and let them know your findings and configuration (pack versions, DMA used/not used etc).
Thanks Vladimir. I have reported this issue on their forum but no response yet. Unfortunately I regularly encounter issues in the HAL libraries of STM32...
"I have reported this issue on their forum but no response yet."
This is their forum. But it isn't the recommended channel to report bugs. So do you mean you have contacted Keil support and created an issue on silver.arm.com?
www2.keil.com/.../silver
Is there any official documentation regarding timing I can refer to? As I pointed out, the ARM documentation does not actually provide detailed information.
Also, please note there's an issue in the ARM documentation which IS posted. I reported this earlier on your forum: http://www.keil.com/forum/61799/
"Their forum" ==> ST, the manufacturer of the MCU I am having an issue with?
Enlighten me, I am not sure what you are getting at. This is the ST forum I posted at (not sure why they have these ridiculously long links...):
my.st.com/.../Flat.aspx
Ah, never mind: the CMSIS driver is written by ARM (=Keil). I got wound up on the fact that it uses the HAL drivers from ST....
I have reported the issue with the link you provided. Thanks again for that link.
