Debugging using hex file on hardware without C source code.
Can i debug a code on hardware without the source C code with just using the .hex file.
I have a hex file that i have read from an LPC2119 microcontroller using flash magic tool. I also have a custom developed LPC2119 board with a Ulink2 debug connector on it and a Ulink2 debugger. Now i want to debug the readed hex file on hardware. Is it possible to debug the hex file on register level or assembly language.?
I am using keil Uvision 5.
  • Can it be done? - Yes, it is possible.
    Can you do it? - That depends on your skills, experience, and level of patience!
    You will need to be very good at assembly code!
    You will need to have a very good understanding of the LPC2119 at the register level!
    You will not have any symbolic information at all:
    * No source file or line number info;
    * No source code;
    * No function names;
    * No variable names;
    * No #define names.
    Perhaps a better question would be: is it worth it? Would you be better off just writing it from scratch ... ?
  • I know a lot how lpc2119 work at the register level. I just dont know the settings that i have to make in keil Uvision 5 to start the debug process with just .hex file.
  • Create a spoof project, uncheck the download before debug option, uncheck run-to-main and then debug the code in situ. Works for ROM, or preprogrammed FLASH, etc.
