I've done some searching on the forum, and this question seems to be asked, but no concrete answer has been given. I'm using the Tiva C with the latest uVision. I have a main.s where all my assembly code is located. When I try to debug, it steps through my startup file, but when it branches to my asm file, it will not jump to it. Even when I set breakpoints in the main.s, it only shows the line in the disassemly window. Thanks for your help!
Did you build with Debug info?
I just barely got it working. I replaced the sarmc3.dll with one my class mate had, and it works perfect. I don't know if this is a bug, but I would think it should do this by itself..
Were the sarmc3.dll files different versions? was the one that worked newer? what versions are they?
is it "barely got it working" or "works works perfect"?
Why do you confuse us with your little detail? Why not give us something worth reading?
I apologize. I can't find a way to upload files to the forum, and all I know is this file is floating around at my university. I replaced it and it worked. Sorry for wasting your time.
You could however explain clearly what versions of uVision and the files you are talking about. Think of it as a technical conversation where precise details are important, and must be committed to words rather than an assumed or telepathic transfer of information.
