Hi
I have connected LPC2148 with 12Mhz Crystal, 15 Mhz PCLK to ENC28J60 with the following PIN Connections.
ARM ENC28J60 PO.4 >>>>> SCK PO.6 >>>>> SI PO.5 >>>>> SO PO.7 >>>>> CS
RESET PIN of ENC28J60 is connected to hardware reset PIN of LPC2148. I have been able to run the compiled program in Proteus and was able to PING the configured IP. No problem at all.
When I run the same with real hardware... it doesnt work. I dont even get a PIN response. What could be the problem ? Should I do anything more with the hardware? Please advise.
Thank you.
ENC INIT
void enc28j60Init(uint8_t* macaddr) {
ENC28J60_CONTROL_DDR |= ((1<<ENC28J60_CONTROL_CS)); IO1DIR = 0x01000000;
CSPASSIVE; // ss=0
IO1CLR = 0x01000000; delay_ms(200); IO1SET = 0x01000000;
PINSEL0 |= 0x1500; S0SPCCR = 0x0e; //0a 6.6m 0c 5.5m 0e 4.7m // org 0e S0SPCR = 0x20;
delay_ms(400);
enc28j60WriteOp(ENC28J60_SOFT_RESET, 0, ENC28J60_SOFT_RESET);
delay_ms(50);
NextPacketPtr = RXSTART_INIT;
// Rx start enc28j60Write(ERXSTL, RXSTART_INIT&0xFF);
enc28j60Write(ERXSTH, RXSTART_INIT>>8);
// set receive pointer address enc28j60Write(ERXRDPTL, RXSTART_INIT&0xFF);
enc28j60Write(ERXRDPTH, RXSTART_INIT>>8);
// RX end enc28j60Write(ERXNDL, RXSTOP_INIT&0xFF);
enc28j60Write(ERXNDH, RXSTOP_INIT>>8);
// TX start enc28j60Write(ETXSTL, TXSTART_INIT&0xFF);
enc28j60Write(ETXSTH, TXSTART_INIT>>8);
// TX end enc28j60Write(ETXNDL, TXSTOP_INIT&0xFF);
enc28j60Write(ETXNDH, TXSTOP_INIT>>8);
enc28j60Write(ERXFCON, ERXFCON_UCEN|ERXFCON_CRCEN|ERXFCON_PMEN);
enc28j60Write(EPMM0, 0x3f);
enc28j60Write(EPMM1, 0x30);
enc28j60Write(EPMCSL, 0xf9);
enc28j60Write(EPMCSH, 0xf7);
enc28j60Write(MACON1, MACON1_MARXEN|MACON1_TXPAUS|MACON1_RXPAUS);
// bring MAC out of reset enc28j60Write(MACON2, 0x00);
// enable automatic padding to 60bytes and CRC operations enc28j60WriteOp(ENC28J60_BIT_FIELD_SET, MACON3, MACON3_PADCFG0|MACON3_TXCRCEN|MACON3_FRMLNEN);
// set inter-frame gap (non-back-to-back) enc28j60Write(MAIPGL, 0x12);
enc28j60Write(MAIPGH, 0x0C);
// set inter-frame gap (back-to-back) enc28j60Write(MABBIPG, 0x12);
// Set the maximum packet size which the controller will accept // Do not send packets longer than MAX_FRAMELEN: enc28j60Write(MAMXFLL, MAX_FRAMELEN&0xFF);
enc28j60Write(MAMXFLH, MAX_FRAMELEN>>8);
// do bank 3 stuff // write MAC address // NOTE: MAC address in ENC28J60 is byte-backward enc28j60Write(MAADR5, macaddr[0]);
enc28j60Write(MAADR4, macaddr[1]);
enc28j60Write(MAADR3, macaddr[2]);
enc28j60Write(MAADR2, macaddr[3]);
enc28j60Write(MAADR1, macaddr[4]);
enc28j60Write(MAADR0, macaddr[5]);
// no loopback of transmitted frames enc28j60PhyWrite(PHCON2, PHCON2_HDLDIS);
// switch to bank 0 enc28j60SetBank(ECON1);
// enable interrutps enc28j60WriteOp(ENC28J60_BIT_FIELD_SET, EIE, EIE_INTIE|EIE_PKTIE);
// enable packet reception enc28j60WriteOp(ENC28J60_BIT_FIELD_SET, ECON1, ECON1_RXEN);
Is this a Proteus forum ?
No simulator provides a 100% fully accurate simulation - they all have certain restrictions & limitations.
You might be using the simulator wrong, and/or not have it configured correctly.
For specific details about the particular simulator and its configuration, operation, and restrictions/limitations, you should consult the documentation for that simulator, and/or contact the supplier for support; eg,
https://www.labcenter.com/
support.labcenter.co.uk/.../
Also, the simulation can only be as accurate as the information you give it - so are you sure that you have 100% exactly and completely modelled your precise hardware?
And, of course, the simulator will not simulate any faults or errors in the hardware you are using.
As its name suggests, use the Debugger to debug your real hardware system ...
