#H in User command does not work as intended
Hello everybody,
I am trying to implement a post build script. Within this script I want to use the full path to the hex file built. Reading the manual to "Key Sequence for Tool Parameters" I guessed that #H gives me what I want. In fact the Help to the User Tab even shows this in an example.
I just inserted #H (without anything else) as a user command just to see what the Build Output would give me. In fact I just see some relative path:
"#H" as User command:
After Build - User command #1: ..\output\Release\MyProject.HEX
#P is working as expected and my Workaround is to use $P#H.
just using #H would just be more clear than that!
Thanks for your replies
Alex
0
