union/struct problem
it works in devcpp (as c project) but not working in Keil. What is my fault.
output must be "12345" but it is not.
typedef union {
        u8      Reg8[5];
        struct
                u8      Select;
                u32     Value32;
        }Regs;
}CreditLoadRegs_t;
const char  MyArray[]={"12345"};
void MyFonc(char *Buf)
    CreditLoadRegs_t *fPtr = (CreditLoadRegs_t *)Buf;
    printf("%s",fPtr->Reg8);
int main(void)
    MyFonc(MyArray);
    return 0;
  • C strings require a terminating NUL character, "12345" doesn't fit in 5 characters, and printf() is going to malfunction if the NUL is missing.
    The code as presented might work.
    If you don't get "12345" *what* do you actually get, this might be far more helpful information than what is expected.
    Returning for main() goes where?
    If you don't provide retargeting/semihosting the printf() will likely fault due to lack of supporting code.
  • Hello,
    Thx for your reply,
    "Returning for main() goes where?"
    Sorry, the code is not original code, just similar. So I don't use the function in main.
    This definition includes null char, MyArray has six bytes but not important.
    because my sample code is wrong. I'm not using printf in original code, I'm using union pointer memory map. Namely as following
    // BufPtr which is usart array includes 5 bytes(it is coming with gprs) so I point with
    // pointer of CreditLoadRegs_t
    // if BufPtr includes "12345", Result must be Ptr32->Select='1'; and Ptr32->Value32="5432";
    // Because of union is packed
    This code works in devcpp but don't work in keil.
    micro is stm32f103, it can be packed as byte and union is packed.
    I didn't find my fault.
    void CreditProc(u8 RW, char *BufPtr)
       if (RW == dREAD)
          // some codes
       }else{
            CreditLoadRegs_t  *Ptr32 = (CreditLoadRegs_t  *)BufPtr;
            // I'm using regs here
            Ptr32->Select &=0x03;
            switch(Ptr32->Select)
               case dSel0:
                   // something
               break;
  • What is my fault.
    Mainly that you're trying to run a 400 meter race before you've fully mastered walking.
    Based on what promises made by the C programming language's syntax and semantics, and/or compiler documention, did you arrive at that belief?
    According to my knowledge about those documents, this code causes undefined behaviour for two reasons: 1) bad pointer gymnastics, 2) abuse of a union.
  • if you're writing about my first message, you're right.
  • And when data came via gprs in BufPtr, I printed it, Data which is in buffer was as expected.
    But output of typedef union was not. (as if union parser is not packed.)
    for example,
    u8 GprsBuf[1024]={1,2,3,4,5,...};
    u8 *BufPtr = GprsBuf;
    for(Cnt=0;Cnt<5;Cnt++)
        printf("%c",BufPtr[Cnt]+0x30); // output = "12345"
    // if I use as following
        printf("%c",Ptr32.Reg8[Cnt]+0x30); // output is wrong
    Do you have any idea?
  • "Because of union is packed"
    What makes you think/say this?
    You seems to think the Keil compiler does something incorrect. But doing things that has undefined outcome means it's expected that you might get different results on different architectures or when using different compilers. So code that "works" on one system isn't automatically correct code even on the system where it "works".
    If you have two architectures with different byte order, then that 32-bit value can print completely differently. You are claiming the data is sent over the network - so the data isn't from a different part of the same program.
    And different architectures have different alignment requirements, which means a union or struct would have different rules for the addition of padding. Another thing here is that on a target with 32-bit align, a union with a 32-bit member value would need to have 32-bit align of the union itself - but that would be incompatible with typecasts from pointers to 8-bit data, unless you have explicitly aligned the 8-bit data.
    Any time you move data between two devices, you shouldn't rely like that on the two devices having identical align and byte order. So programs doing networking have special functions for converting to/from "network byte order". Even if you have written the code for both the sender and the receiver, you should still add proper pack/unpack of the data, to allow you to change compiler and/or architecture on one side and stay compatible with the other side.
  • Dear Per Westermark,
    Thanks for your reply,
    I don't think the keil compiler does something incorrect. Keil is best compiler for arm mcus. I'm just trying to find the my fault.
    " What makes you think/say this? "
    I don't use "#pragma pack(push,1)" or __packed keywords for pack process but Are byte arrays already packed? The union includes byte array so I'm thinking that it is packed.
    I have used many times differently in keil before and I didn't see not packed
    for example, below,
    typedef u8  unsigned char;
    typedef u32 unsigned int;
    u8 Buf[]={1,2,3,4,5,0};
    typedef union {
        u8      Reg8[5];
        struct
            u8      Select;    // 1 byte
            u32     Value32;   // 4 byte
        }Regs;
    }CreditLoadRegs_t;
    CreditLoadRegs_t *Ptr = (CreditLoadRegs_t *)Buf;
    Ptr->Reg8[0] = Ptr->Select = 1
    Ptr->Value32 = Ptr->Reg8[1] | (Ptr->Reg8[2] << 8) |
                   (Ptr->Reg8[3] << 16) | (Ptr->Reg8[4] << 24)
                 = 0x5432
    Am I thinking wrong? if It is wrong, why?
  • A byte array is packed.
    But this most definitely is not a byte array:
    struct {
    } Regs;
    Value32 would want 32-bit align.
    So you would end up with:
    struct {
        u8      pad1[3];
    } Regs;
    Now map that in your union, and you'll notice that you have 3 bytes of your byte array that maps to air.
    Next thing - if your byte array is packed from a data structure that has a different byte order compared to what your processor uses, then even the struct was packed you would still get the wrong content seen in Value32.
  • struct {
    } Regs;
    You're right. This structer is not packed. But I thought that union make it pack.
    Result, I think as following
    struct
            u8      unused[3];
        }Regs;
    Reg8[0]=Select
    Reg8[1]=unused[0]
    Reg8[2]=unused[1]
    Reg8[3]=unused[2]
    Reg8[4]=LSB_Value32;
    So the structer must be __packed
    typedef union {
        u8      Reg8[5];
        __packed struct
        }Regs;
    }CreditLoadRegs_t;
  • The union is only about overlaying data - not packing data.
    And it isn't intended to overlay as a way to type-convert, but to allow conditional existence of data from a time when RAM was at a premium.
    Any and all type conversion performed using unions are a kind of abuse. When done correctly, it can in some limited cases be used in a "correct" way without undefined behavior. But it is a slippery slope - the language standard didn't intend you to write to one member of the union and read out the data using a different member of the union.
  • you're quite right, thanks a lot
  • But I thought that union make it pack.
    In case of doubt, and definitely in case of surprising behaviour like the one discussed here, you really should replace such thought by actually looking up documentation.
    No. It doesn't have to be packed. The job at hand can and should be done entirely without any packed structs, unions and fishy pointer casts. You'll want to look up the term "serialization".
  • Dear Hans-Bernhard Broeker
    Thanks your response,
    Sorry, I didn't understand why it doesn't have to packed exactly. I have read a few books about standart C , embedded C and data structers in C. But I never read/see about serialization which is not packed or alligned memory in mcus.
    I'm asking for learning,
    if possible, can you give me a small sample or/and can you show/prefer me a source/book about this subject.
  • A common way of serializing data is to write code that takes a uint8_t pointer and inserts or retrieves different data types byte-by-byte in a well-defined order.
    So if serializing a int32_t, the serialize function may emit it from high-to-low byte. And the deserialize function would extract and join from high-to-low. That means that the byte stream transmitted will be compatible even if the sender and receiver have different byte order.
    And it also means that it doesn't matter if the sender and receiver have different rules for padding between fields in a struct.
    So you might do:
    p = transmit_buffer;
    p = pack_u32(p,my_struct.my_u32);
    p = pack_u32(p,my_struct.other_u32);
    p = pack_u16(p,my_struct.some_u16);
    p = pack_string(p,my_struct.string,sizeof(my_struct.string));
    and on the other side do something like:
    p = receive_buffer;
    p = extract_u32(p,&my_struct.my_u32);
    p = extract_u32(p,&my_struct.other_u32);
    p = extract_u16(p,&my_struct.some_u16);
    p = extract_string(p,my_struct.string,sizeof(my_struct.string));
    Or maybe switch parameter/return value and do:
    p = receive_buffer;
    my_struct.my_u32 = extract_u32(&p);
    my_struct.other_u32 = extract_u16(&p);
    This is a situation where C++ is very handy, since it can keep track of the size of the transmit buffer and fail if trying to insert more than what fits. Or keep track of the number of available bytes in the receive buffer and fail if the code tries to extract more than was available.
    With C, you need additional parameters or global variables to keep track of all the state information when packing/unpacking.
    But with explicit serializing, you can get very robust code that works with different architectures, compilers, optimization levels, computer languages etc. The two sides can completely change order and data types of the internal data as long as they both agree on the order/size/type of the individual values stored in the serialized data.
  • Thank you a lot for sample and information,
    I had already known serializing but I hadn't known its technical name as serializing.
    I'm using it but usually for big string/data sending/receiving, if I'll send or receive little size data which is also combinations of difference variable type, I'm using packed structs as rx and tx buffer. (Because serializing process is slowing for parsing process)
    But if there are big data size, I'm using serializing process.
    __packed typedef struct{
      u8    Reg8;
      u32   Reg32;
      float Flt;
      u16   Reg16;
    }Comm_t;
    // sender side
    Comm_t  SenderCommRegs;
    UartCanUsbSenderFonc(Comm_t *cPtr);
    UartCanUsbSenderFonc(&SenderCommRegs);
    // receiver side
    Comm_t  RecvCommRegs;
    UartCanUsbRecvFonc(Comm_t *cPtr);
    UartCanUsbRecvFonc(&RecvCommRegs);
    in fact, I'm a little confused.
    I can test it but if I use __packed keyword also, Can the keil compiler add byte/bytes for padding?
    if it is not add, The union must cover struct regs. isn't it?
    typedef union{
       u8 Areg8[5];       // 5 bytes u8 array
       __packed struct{
           u8  Temp8;     // 1 byte
           u16 Low16;     // 2 bytes
           u16 Hi16;      // 2 bytes
       }Regs;
    }x_t;
