union/struct problem
it works in devcpp (as c project) but not working in Keil. What is my fault.
output must be "12345" but it is not.
typedef union {
        u8      Reg8[5];
        struct
                u8      Select;
                u32     Value32;
        }Regs;
}CreditLoadRegs_t;
const char  MyArray[]={"12345"};
void MyFonc(char *Buf)
    CreditLoadRegs_t *fPtr = (CreditLoadRegs_t *)Buf;
    printf("%s",fPtr->Reg8);
int main(void)
    MyFonc(MyArray);
    return 0;
  • One could presumably use sizeof() and offsetof() to arrive at a conclusion.
    I would be careful as it is very easy to get caught with an alignment fault on ARM devices if you are not paying attention.
  • "Because serializing process is slowing for parsing process"
    You'd be surprised at how fast serializing can be. When your web browser retrieves a web page, it gets serialized data. When it processes a JPG image, it's decoding serialized data. When you view a BluRay movie, the player decodes serialized data.
    A "file format" is a protocol for how the data should be serialized into the file so writer and reader will be able to both understand the content. All networking happens with serialized data. It's just that in some situations, one layer of serialized data may contain "blobs" of unknown payload, that a different protocol layer will be able to work on.
    In the end, you should avoid having transfers or data sharing contain data blobs where the content is raw memory dumps unless the data is known to just be a byte stream. It's a short-term cost/time-saving that tends to give lots of interesting problems.
