complier, failure, code , debugging
The code is written well, but when I press build and enters the debug window, it misses some lines.
I thought it might be the intending problem, but is the problem the Keil software.
In debugger window, I am not able to put breakpoints, because the Keil assumes that the line is not present in the code.
