There is an issue (it's not a bug because of reasons) where if you use armclang at -O0 optimisation with no parameters specified in the main function, the initialisation code contains a coded breakpoint. This will stop the code from running before main is reached.
There are multiple work arounds including:
1) Using MicroLib
2) Disabling semihosting manually:
__asm(".global __use_no_semihosting\n\t");
Note that the following funcitons will need to be retargeted:
extern "C" void _sys_exit(int ch) { } extern "C" void _sys_command_string(int ch) { } extern "C" void _ttywrch(int ch) { }
3) Use the following, which apparently is used automatically by armclang on higher optimisation levels:
__asm(".global __ARM_use_no_argv");
Apparently the coming fix "will be a better documentation about the symbol __ARM_use_no_argv and why it is needed when using -O0."
Just wanted to let people know in case it happens to them.
Thanks for sharing it!
Appreciate it!
Hello Stephen ,
Thanks for posting this. It has good information. I didn't find it until just now.
1) I thought I would add some additional links, for future forum users to reference.
You can read more about using the Hardcoded Breakpoint issue in this article:
http://www.keil.com/support/docs/3614.htm
2) You mentioned compiling at optimization level 0 using ARM compiler 6 (ARMCLANG).
For ARMCC compiler 5 the optimization 0 was the default. However, for ARMCLANG, optimization level 1 is the recommended optimization for ARM-based microcontroller projects.
See http://www.keil.com/appnotes/docs/apnt_298.asp
There is a temptation to thing level 2 optimization of ARCC works the same as level 2 for ARMCLANG, but there is not an apple-to-apples comparison.
See: http://www.keil.com/support/docs/3996.htm
For a bit more detail on what Stephen mentioned, look at the "Note" section at the bottom of this page:
www.keil.com/.../armclang_mig_udb1499267612612.htm
It explains more on why you should not use level 0 optimization, and what all is involved to compile at level 0 optimization using ARMClang on an ARM-based microcontroller .
Oh one more cross link,
Here is an article that tells how to ask for a C-style linkage to the C++ module (the extern "C" in the commands Stephen posted):
http://www.keil.com/support/docs/3223.htm
Excellent insights! One little improvement is that you don't need to use inline assembly. The following definition in any module (.c/.cpp file) will work as well:
int const __ARM_use_no_argv = 0;
