Keil RTX interrupt handling
I'm using lpc1768 controller keil RTX rtos and uart receive function by an interrupt. I was set a NVIC priority using NVIC_SetPriority(UART1_IRQn,1) while thread processing it don't goes to IRQHandler if any uart rx interrupt was occur. After finish the thread process then goes to IRQ Handler. I don't know how to set a high interrupt priority using RTOS. Please help me to solve this issue.
Thanks & Regards,
Prasanth.
  • Is the RTOS executing in privileged mode?
    The following depends on the version of RTX you are using...
    Did the thread disable interrupts during its execution?
    disable_irq()  //or similar
    enable_irq()  //or similar
    Look for tsk_lock(), as well.
  • Thanks for your response Zack Havens. Yes my RTOS execution in privileged mode and version is 4.81.1. The functions you mentioned disable_irq() and enable_irq() both are defined but commented in cmsis_armcc.h. They didn't gets called anywhere in a program. Another function you mentioned tsk_lock() i can't find it from the program. what i wanna do next?
