LwIP and compiler 6
Good moorning,
I am trying to use LwIP to do a RAW Socket TCP connection.
I have did it without problems but i used the compiler 5, i want add this development to another proyect that i am doing but in that i use the compiler 6.
When i try to migrate it, appears too many compile errors.
Do you know if there are any limitations?
Someone use LwIP with the compiler 6?
I am working with a ST microcontoller, the STM32F779NI.
The IDE that use is the KEIL MDK.
I hope you can help me.
Thank you very much for you time.
  • That usually happens when there's one (or a few) actual errors which lead to a load of resultant errors.
    eg, if a header file is not found that is just one error to fix - but it will result in errors for each and every thing that is declared in that header.
    So the secret is to consider the earliest error first - fix that error, and see how many more disappear.
    This is entirely general - nothing specific to Keil or LwIP.
    "Do you know if there are any limitations?"
    almost certainly not - it's probably just a matter of correctly configuring the project.
  • Good moorning,
    I believe that i have not self explained well
    I will try to explain with an overview:
    Main development - Use ARM Compiler 6 - Its Work
    Ethernet development - User ARM Compiler 5 - Its Work
    Ethernet development Migration - Use ARM Compiler 6 - Not Work
    Ethernet development Migration, its the same program that Ethernet development. Both dont show compile Errors.
    Update:
    01/02/2019
    I have been analized the problem and i found that when i use ARM Compiler 5 i can receive packages in ethernetif (LwIP File), but with the ARM Compiler 6 not.
    Its too much strange.
    ¿Someone have this problem or have an idea to resolve it?
    Thanks for you time and help
  • So you have a working version, and a non-working version.
    You need to narrow down where the non-working version is failing - it's no use just saying, "it doesn't work".
    Use the debugger to step through the code - is it getting stuck somewhere?
    Are you getting error returns?
    Instrument both the working & non-working versions, and look where they differ - then focus your debugging at those points ...
  • I found the error, but i dont know the exactly sintaxis to fix it.
    #if defined ( __CC_ARM   )
    ETH_DMADescTypeDef  DMARxDscrTab[ETH_RXBUFNB] __attribute__((at(0x2007C000)));/* Ethernet Rx DMA Descriptors */
    ETH_DMADescTypeDef  DMATxDscrTab[ETH_TXBUFNB] __attribute__((at(0x2007C080)));/* Ethernet Tx DMA Descriptors */
    uint8_t Rx_Buff[ETH_RXBUFNB][ETH_RX_BUF_SIZE] __attribute__((at(0x2007C100))); /* Ethernet Receive Buffers */
    uint8_t Tx_Buff[ETH_TXBUFNB][ETH_TX_BUF_SIZE] __attribute__((at(0x2007D8D0))); /* Ethernet Transmit Buffers */
    #elif defined ( __ICCARM__ ) /*!< IAR Compiler */
      #pragma data_alignment=4
    #pragma location=0x2007C000
    __no_init ETH_DMADescTypeDef  DMARxDscrTab[ETH_RXBUFNB];/* Ethernet Rx DMA Descriptors */
    #pragma location=0x2007C080
    __no_init ETH_DMADescTypeDef  DMATxDscrTab[ETH_TXBUFNB];/* Ethernet Tx DMA Descriptors */
    #pragma location=0x2007C100
    __no_init uint8_t Rx_Buff[ETH_RXBUFNB][ETH_RX_BUF_SIZE]; /* Ethernet Receive Buffers */
    #pragma location=0x2007D8D0
    __no_init uint8_t Tx_Buff[ETH_TXBUFNB][ETH_TX_BUF_SIZE]; /* Ethernet Transmit Buffers */
    #elif defined ( __GNUC__ ) /*!< GNU Compiler */
    ETH_DMADescTypeDef  DMARxDscrTab[ETH_RXBUFNB] __attribute__((section(".RxDecripSection")));/* Ethernet Rx DMA Descriptors */
    ETH_DMADescTypeDef  DMATxDscrTab[ETH_TXBUFNB] __attribute__((section(".TxDescripSection")));/* Ethernet Tx DMA Descriptors */
    uint8_t Rx_Buff[ETH_RXBUFNB][ETH_RX_BUF_SIZE] __attribute__((section(".RxarraySection"))); /* Ethernet Receive Buffers */
    uint8_t Tx_Buff[ETH_TXBUFNB][ETH_TX_BUF_SIZE] __attribute__((section(".TxarraySection"))); /* Ethernet Transmit Buffers */
    #endif
    In this code fragment the buffers and the DMA descriptors are established, without them I can neither receive nor send packets.
    The code compiled and gave no errors because for compiler 6, there is no option and all were disabled.
    In order to make this part work I have to migrate it to compiler 6, according to the migration manual I should use this syntax:
    __attribute__((section(".ARM.__at_address")))
    //armlink in Arm Compiler 6 still supports the placement of sections in the form of .ARM.__at_address
    But when i have tried to migrate the code, i get thesses errors of syntax:
    1.- First Try
    ETH_DMADescTypeDef  DMARxDscrTab[ETH_RXBUFNB] __atribute__((section(".ARM.__at_0x2007C000")));        /* Ethernet Rx DMA Descriptors */
    ethernetif.c(80): error: expected ';' after top level declarator
    2.-Second Try
    ethernetif.c(81): warning: type specifier missing, defaults to 'int' [-Wimplicit-int]
    ^ ethernetif.c(81): error: redefinition of 'DMARxDscrTab' with a different type: 'int [4]' vs 'ETH_DMADescTypeDef [4]'
    ethernetif.c(80): note: previous definition is here
    ETH_DMADescTypeDef DMARxDscrTab[ETH_RXBUFNB]; ^
    ethernetif.c(81): error: expected ';' after top level declarator
  • Good Moorning,
    I finaly resolved it.
    First i found the correct sintaxys for DMA reserve.
     // Ethernet Rx DMA Descriptors
       __attribute__((section(".ARM.__at_0x2007C000")))  \
       __attribute__((section(".ARM.__at_0x2007c080")))  \
       __attribute__((section(".ARM.__at_0x2007C100")))  \
       __attribute__((section(".ARM.__at_0x2007D8D0")))  \
    Second i changed the memory map in sct file.
    I changed the size of IRAM1, for have a space reserved.
    RW_IRAM1 ADDRESS SIZE{ ;RW data
            .ANY(+RW +ZI)
    ; *** Scatter-Loading Description File generated by uVision ***
    LR_IROM1 0x08000000 0x00200000  {    ; load region size_region
      ER_IROM1 0x08000000 0x00200000  {  ; load address = execution address
       *.o (RESET, +First)
       *(InRoot$$Sections)
       .ANY (+RO)
       .ANY (+XO)
      RW_IRAM1 0x20020000 0x0005C000  {  ; RW data
       .ANY (+RW +ZI)
      RW_IRAM2 0x20000000 0x00020000  {
       .ANY (+RW +ZI)
    Thank you very much for you time and help.
    Kinds Regards
