mdk-arm 5.24 link j-link report: Error: Cannot load driver 'a:\Keil_v5\ARM\Segger\JL2CM3.dll'.
Possible Reasons: - Driver DLL could not be found in the specified path - Driver DLL requires additional DLL's which are not installed - Required Hardware Drivers are not installed Debugger aborted !
mdk-arm 5.24 preview no this problem
I confirm I have the same problém On 5,23 all workink OK
The same problem. Keil removed 5.24 from web, By the way. Keil approach is not very serious
In a few days MDK-ARM V5.24a will be released. Meanwhile please use V5.23, offered at: www2.keil.com/.../install
5.24A is now available for download :)
Did 5.24a solved the problem for you?
After update to 5.24a i still suffer same problem. Do i have to remove keil completely and then install fresh?
Regards, Adib.
Even fresh install 5.24a does not work. Adib.
Is your J-Link original or Chinese clone?
With the help of Keil support I isolated the remaining issue.
I had an old JLink-dll in my path that was used. I can control the version of used dll in the debugger dialogue. The number 6.14 that was shown was not the one given in Keil directory.
I removed the old dll from my path (potentially I put a more recent one).
And no, I am not using China nor EDU Version of JLink :-) I am using JLink Base.
Regards, Adib. --
