Hi, I have several ARM Cortex-M based boards such as Arduino DUE, Nordic's PCA10040 (nRF52-DK), STM32F4 discovery, and STM32L4 discovery.
I use Keil uVision 5 (ARM-MDK, version 5.23.0) on my 64-bit Windows 7 and 10 desktops.
To be more specific;
Toolchain Path: C:\Keil_v5\ARM\ARMCC\Bin C Compiler: Armcc.exe V5.06 update 4 (build 422) Assembler: Armasm.exe V5.06 update 4 (build 422) Linker/Locator: ArmLink.exe V5.06 update 4 (build 422) Library Manager: ArmAr.exe V5.06 update 4 (build 422) Hex Converter: FromElf.exe V5.06 update 4 (build 422) CPU DLL: SARMCMS.DLL V5.23 Dialog DLL: DCM.DLL V1.15.0.0 Target DLL: Segger\JL20M3.dll V2.99.23.0 Dialog DLL: TCM.DLL V1.27.0.0
I'm planning to use CI (Continuous Integration) programs; I will choose Jenkins or Atlassian Bamboo.
The server which will host the CI program is using the 64-bit Windows OS and Keil uVision 5 is also installed on the server computer.
So, both the server computer and my working computer have the above tools installed.
Back to my question,
I want to compile and build Keil projects via command line (CMD or PowerShell commands).
By learning this, I can configure the CI program to build Keil projects.
What should I type to compile/build Keil projects at the command line?
Are there documents about parameters of Armcc / Armasm / ArmLink, etc?
-Best Regards
http://www.keil.com/support/man/docs/uv4/uv4_commandline.htm
