I need to run 2 functions or process simultaneously, like in 2 function, first function will be running continuously and when it's time to run the second function, it runs initially and later on it won't work continuously.
Used ISR for the second function to run the process in the background, but not getting expected result. Kindly suggest me on this.
Thank you.
