We use the CMSIS-Driver for SPI/I2C communication inside our project. Our application will run on 2 different hardwares. We would like to use the same binary for both devices. We can detect the current hardware, but it is not possible to change the pin / ports of the CMSIS-Driver dynamically. Because the different hardwares havn't exactly the same pin layout.
The pin/ports are set with #defines and therefore of corse it isn't possible to change anything dynamically.
For our proposal it would be great if we could adjust the pin/ports after startup but before we call the initialize function (Driver_SPI1->Initialize(...)). This could be achieved if e.g. the resource object isn't defined static const.
// SPI1 Resources SPI_RESOURCES SPI1_Resources = { ... }
Then we have access to the pin layout with:
extern SPI_RESOURCES SPI1_Resources; ... SPI1_Resources.io = /* new pin config */
Or if the CMIS-Driver has some function to access the resources object or to adjust the settings:
// with resource object access *SPI_RESOURCES SPI1_GetResources(void){return &SPI1_Resources; } // or with settings access int SPI1_ChangePinLayout(...){return SPI1_ChangePinLayout(...,&SPI1_Resources); }
github.com/.../CMSIS_5 is a better place to submit your requirement for CMSIS-Driver
