Hi Friends,
presently I'm using the micro controller LPC1114FBD48 of ARM family.
now i'm generating the frequency in the range of 9.6hz to 12hz using timer registers and interrupts. now i had generated the 9.6 hz but remaining frequencies are passing through interrupt.
please guide me to move further and below is my code.
oid TIMER16_0_IRQHandler(void) { if(LPC_TMR16B0->IR & (1<<4)) //capture interrupt { if(LPC_TMR16B0->CCR ==5){ LPC_TMR16B0->TC = 0; //reset timer LPC_TMR16B0->CCR =6; } else{ period_time = LPC_TMR16B0->CR0; //read time LPC_TMR16B0->CCR =5; } LPC_TMR16B0->IR |= (1<<4); //reset capture interrupt } }
int main(void) { SystemInit(); LPC_SYSCON->SYSAHBCLKCTRL |= (1<<7);//enable clock CT16B0 //init io CT16B0_CAP0 LPC_IOCON->PIO0_2 = (1<<1)|(2<<3); //CT16B0_CAP0 & pullupCAP0FE LPC_TMR16B0->CTCR = 0; //use timer mode LPC_TMR16B0->CCR = 5; //rising LPC_TMR16B0->PR = 47; //prescaler 48 NVIC_EnableIRQ(TIMER_16_0_IRQn); //enable interrupt LPC_TMR16B0->TCR = 1; //and run timer LPC_IOCON->PIO1_9 |= (1 << 0); // Pin no 17 = CT16B1_MAT0(checking out put) LPC_TMR16B1->MR0 = 1000;//3500;//11200; // 50% Duty Cycle LPC_TMR16B1 ->MR3 = 2000; LPC_TMR16B1 ->PR=4000; }
