include path problems
receiving the following error in MDK Lite 5.23 uvision5 for arm lpc1768
C:\Keil_v5\ARM\PACK\Keil\LPC1700_DFP\2.3.0\RTE_Driver\UART_LPC17xx.c(75): error: #5: cannot open source input file "RTE_Device.h": No such file or directory
This is despite the file showing under the CMSIS Driver node in the project tree. I try to re-add the file but it wont, stating the file is already included. Stumped
  • >> I try to re-add the file but it wont, stating the file is already included.
    It is not complaining it can't find the .C file, it is complaining that the Include Paths in the C/Options dialog is incomplete or poorly ordered. FIX THAT
    You don't add .H files to the project, you add .C files, and if it is compiling this one, or trying, it clearly already knows about it. Adding the .C file again won't fix this.
  • Thanks for pointing in the right direction Pier. So I noticed that when I was selecting and 'resolving' the components in the run-time manager the RTE files were not being selected along w the 'startup' and 'system' files. Manually selecting 'startup' under the 'Device' node resolved the issue.
    Thnaks Again
    Wayne
