Show function, variable
Hi!
It is my first post here, so don't tread on me :)! I want to ask, how to watch result of function?
I don't know what to do with this - I tried "Watch 1", but I can't get satisfied result - I mean see "EQUAL" or "DIFFERENT".
I attached my code here:
#include <LPC21xx.H>
#include <string.h>
#define NULL 0
enum CompResult{DIFFERENT, EQUAL};
enum CompResult eCompareString(char pcStr1[], char pcStr2[]){
        unsigned char ucCounter;
        for(ucCounter=0; pcStr1[ucCounter]==pcStr2[ucCounter]; ucCounter++){
                if(pcStr1[ucCounter]==NULL){
                        return EQUAL;
        return DIFFERENT;
int main(){
        char pcStr1[] = {'a','b','c', NULL};
        char pcStr2[] = {'d','e','f', NULL};
        eCompareString(pcStr1, pcStr2);
        return 0;
Thank's for help and have a good night ;)!
  • You would have to assign the result to a variable, and watch that variable.
    But take care that the variable doesn't get optimised away!
    And note that an embedded microcontroller program should not return from main() - think about where it would return to ...
  • Andrew Neil
    I should do something like this?
    x = EQUAL;
    y = DIFFERENT;
    int main(){
      x,y;
    I tried sth like this, but it doesn't work - where I did a mistake?
  • Tells us next to nothing.
    Shown exactly what you tried.
    Describe exactly what you did with it.
    Describe what you expected to happen.
    Describe what actually to happened.
    What testing/investigation/debugging have you done to account for the discrepancy?
    When actual behaviour differs from expected behaviour, first check your expectations.
  • Ok, so I tried this below (see code). I debuged the program and I wirote to Command Window variable x and then y. I'm expecting a result when pcStr1[] == pcStr2[] then should return EQUAL otherwise DIFFERENT - I want to see this.
    I saw that for the value x (stands for EQUAL) assign value 0x00000001 for y 0x00000000.
    #include <stdio.h>
    #include <string.h>
    #define NULL 0
                            return EQUAL;
            return DIFFERENT;
    int main(){
            char pcStr2[] = {'d','e','f', 'e', NULL};
            static volatile int x;
            static volatile int y;
            x = EQUAL;
            y = DIFFERENT;
            x;
            y;
  • So how do you expect the value of either x or y to get changed by the code you showed?
    This is a basic 'C' question - nothing to do with Keil or ARM or microcontrollers.
    I think you need to take a step back, get a good 'C' textbook, and work through learning the 'C' programming language on a PC before complicating the issue with embedded microcontrollers
    Here are some 'C' learning & reference resources - including a free online textbook: blog.antronics.co.uk/.../
  • Andrew - I think, I have sth wrong wtih setting in Keil..let me explain.
    First code (C online Compiler):
    #include <stdio.h>
    #include <string.h>
    #define NULL '\0'
                            return EQUAL;
            return DIFFERENT;
    int main(){
            char pcStr2[] = {'a','b','d', NULL};
        printf("Resullt: %d\n", eCompareString(pcStr1, pcStr2));
        return 0;
    And result it's ok. It shows "1" when Strings are the same, otherwise show "0".
    Second code (C++ online Compiler):
    #include <iostream>
    using namespace std;
    #define NULL 0
                            return EQUAL;
            return DIFFERENT;
    int main(){
        cout << "Result: " << eCompareString(pcStr1, pcStr2) << endl;
        return 0;
    Result above is the same. And here i got the code in Keil:
    #include <stdio.h>
    #include <string.h>
    #define NULL 0
                            return EQUAL;
            return DIFFERENT;
    int main(){
        char pcSource[] = {'a','b','c', NULL};
        char pcDestination[] = {'d','e','f', NULL};
        CopyString(pcSource, pcDestination);
        printf("Result: %d\n", eCompareString(pcStr1, pcStr2));
    And when I click to debug (Ctrl + F5) then I can't deub my "main.c" program - it's happens always, when I use:
    #include <stdio.h>
     printf("...", ...);
