Hi fellas I'm trying to find out where can I put/run our Linker's commands. for example this command:
armlink [... your normal options...] --verbose --list err.txt
I don't know how to use this. :(
There are many ways to achieve this like you can put your commands into a batch file and click on the file or you can open up a command line and type in the commands from there or you can do lots of other things but you must remember to either specify the path to the command or modify your path to include the directories where the command exists and that path can either be a system or a user path.
Thanks for reply What's the simplest way? Which way do you recommend to do this? What do you mean "you can open up a command line"? How can I open up a command line? whatdo you mean of "command line"? do you mean Microsoft command prompt (in Windows)?
Is any tutorial or Application Note about running Linker's commands?
Where/How can I find all of those ways to run a linker's command?
In the Project options - on the appropriately-named 'Linker' tab:
www.keil.com/.../uv4_ca_ovwconfigdialogs.htm
http://www.keil.com/support/man/docs/uv4/uv4_dg_adsld.htm
