Pointer to 2D array
On Keil C51 compiler using an already posted solution I get the following warning
Mail.c(256): warning C182: pointer to different objects
on "pointer = &tab1;"
int (*pointer)[100][280]; // pointer creation
pointer = &tab1; //assignation
(*pointer)[5][12] = 517; // use
int myint = (*pointer)[5][12]; // use
WHY?
  • Isn't it a bit fun that the compiler complains about "pointer to different object", but you do not show us what the two objects are?
    We - the readers - can't know what your tab1 is. But we can wonder if you have thought a bit about the use of & before the name of an array variable.
  • Sorry, the code shown was from another forum and is the answer to another question which i just cut and paste to try.
    int tab1[100][280];
    to my limited knowledge &tab1 is the location tab1[0][0]
  • OK here is my exact code, nothing i do seems to cure the problem...could it be the data space that objects are in??
    int xdata RefPSX [PSX_SIZE][NUMBER_VOLTS]; //xdata space
    int (xdata * xdata Ptr)[PSX_SIZE][NUMBER_VOLTS]; //pointer in xdta space pointing //to xdata 2D array
    Ptr=RefPSX; // init pointer ****warning C182: pointer different objects****
    (*Ptr)[1][2] = 4; // use
