Hello. I was trying to "build target" with the following codes:
AREA ARMtest, CODE, READONLY ENTRY MOV r0,#0 ;clear total in r0 MOV r1,#10 ;FOR i = 1 to 10 Next MUL r2,r1,r1 ; square number MLA r0,r2,r1,r0 ; cube number and add to total SUBS r1,r1,#1 ; decrement loop count BNE Next ;END FOR END
However, 2 errors were reported.
Try Keil\test.asm(1): error: A1163E: Unknown opcode ARMTEST, , expecting opcode or Macro Try Keil\test.asm(2): error: A1355U: A Label was found which was in no AREA ".\Objects\Try1.axf" - 2 Error(s), 0 Warning(s). Target not created.
I have no idea what is not correct. Does anyone know what happen? Please help. Thank you.
