IN C-language:- #include<stdio.h> int main() { while(1) { printf("hai\n"); } } output: hai hai hai . . . like this upto stack overflow
IN EMBEDDED c:- #include<reg51.h> sbit led=P1^0; int main() { led=0; while(1) { led=~led; } }
at what time stack overflow takes place in microcontroller can any one help me
hi kumin. you get stack overflow when you use the stack. simple loop wont do it. good way dr ghela told me was main() { main(); }. he sais code goes *** up
The same time it overfolws in any other stack-based system!
The "Stack" is a standard concept used throughout computer science - you should be able to look this up in your textbooks, and find plenty of information on the interwebs...
What is the *** up, when do they go pear shaped also?
