Anyone suggest me how to implement delay_microsecond in CMSIS RTOS?
here is my code
#include "cmsis_os.h" void start_alive_led(void const * argument) { /* USER CODE BEGIN start_alive_led */ /* Infinite loop */ for(;;) { HAL_GPIO_WritePin(alive_GPIO_Port,alive_Pin,GPIO_PIN_SET); osDelay(500); HAL_GPIO_WritePin(alive_GPIO_Port,alive_Pin,GPIO_PIN_RESET); osDelay(500); } /* USER CODE END start_alive_led */ }
the task/thread function works fine with 500ms
How to acheive delay in micro seconds - usec
i need to implement IR buster, so i need usec delay for each 1 and 0..
please help thanks
Consider setting up a free running high speed counter on chip.
Works well for me.
Don't use interrupt based delays, you almost certainly can't sustain a 1MHz rate. Use a free running timer, and delta the values. If you part supports DWT_CYCCNT use that to count CPU cycles.
Thanks for your kind reply.
I'm learning RTOS bit by bit.
can you please give me a sample code using "DWT_CYCCNT".
code from initilization untill delay time creation please.
im using STMF103 microcontroller.
Thank you for your help.
