Keil uVision "find in files" problem
I was trying to search for a particular for() loop in my code, and put this into the Find in Files box:
for (temp
The "Regular expression" tickbox was left unticked.
However when clicking Find All, a messagebox announced "Regular expression might be wrong, please check."
However the regular expression tickbox is unticked.
This is repeatable, with
anything (anything
in the search field.
Am I doing something unreasonable or is this a bug?
John
  • It has been fixed in MDKv5.22 and you should not face it in MDKv5.23
    For time being, either contact technical support for patch or revert to older versions:
    www.keil.com/.../
    www2.keil.com/.../silver
  • Hi Sankalp,
    I got another issues concerning 'Find in Files':
    1) In 'Find in Files' checkbox 'Match case' dont have any effect.
    This is annoying and complicates searching relevant lines.
    2) If 'File types' is left blank, and 'Look in' is a dedicated directory (with 'Include sub-foldes' checked in my case), then the search result is always empty.
    This is irritating, because in case of 'Current Document' or 'Current Projekt' it works like 'File types' = "*.*". Now I know it and keep it in mind. But sometimes (I dont know in which cases) when I open the Find in Files dialog, then 'File types' field appears empty and I have to fill it explicitely.
    Please consider about fix these.
    When will be MDKvV5.23 availible? (Actually the download link leads to v5.22)
    Best regards
    Matz.
