ARM 7 Assembly memory areas are not initialized
I am trying to write simple program using ARM 7 Assembly, but I cannot initialize memory region with simple data. Here is an example
    AREA    RESET, CODE, READWRITE
    ENTRY
    LDR   r0, =SortArray ;load start address
    LDR   r1, =SortArrayEnd ; load end address
    STR  r15, [r0]
    LDR r4, [r0]
    SUB r2, r2, #1 ; r2 contains (LENGTH-1)
    MOV r6, #0 ; r6 sum set to 0
STOP B STOP
    LTORG
    AREA my_data, DATA, READWRITE
    ALIGN
SortArray
    DCD 1,5,20,32,13,66,3,5,23,64,112,66,22
SortArrayEnd
    END
This doesn't loads data in memory, in debug mode SortArray in r0 register points to 0x40000000 and SortArrayEnd points to 0x40000034, but there is no data
Memory map for data in separate area - i.stack.imgur.com/JNAK2.png
But as you may have noticed there is instruction for storing data in the memory STR r15, [r0] and it works perfectly data is stored there.
Next example works but as you can see I placed data inside code area and made it READWRITE that is probably bad idea. But in this case I can see my data in the memory.
SortArray
SortArrayEnd
    ENTRY
    STR  r15, [r0]
    LDR r4, [r0]
STOP B STOP
    LTORG
    END
Here is my memory map it starts from 0x00000000
Memory Map WIth Data placed in code Area - i.stack.imgur.com/Vfkwf.png
Please help to find the problem, I have spent several days trying to figure out what is wrong.
I am using uVision 4 and device is LCP2148.
  • You must store the initial values in flash - RAM can't keep the content when you power off the unit.
    Same with C programs - they have startup code that copies any initial values from flash to RAM and then zero-fills the rest of the RAM.
  • Thank you for answer, could you please provide correct example how should I use variables.
    For example how can store something like static variables in Asseembly.
    Thank you.
  • Have your code call __main, and name your entry point for code after the static initialization called main. Look at the startup_foo.s for your processor/board for an example of how to start things before handing off to user code
    Or manage the load region yourself by examining what __main is doing
  • Thanks for answer as you can see I am using RESET so it is called directly without initialization stuff (stack configuration and so on).
    So I just need this work just for study purpose.
    Please suggest what should I try, how should I store this variables correctly, as far as I know object files (linux) contains different sections including section with static variables, how can I achieve the same result here ?
  • When the processor starts the RAM holds random content, you must copy whatever you need to it from ROM. You need to implement an equivalent to memcpy and memset to do the work of setting up the RAM.
    Using the runtime library to do your donkey work should look something like this
                    AREA    STACK, NOINIT, READWRITE, ALIGN=3
    Stack_Mem       SPACE   1024
    Stack_Top
                    AREA    RESET, CODE, READONLY
                    ARM
    Vectors         LDR     PC, Reset_Addr
    Reset_Addr      DCD     Reset_Handler
    ; Reset Handler
                    EXPORT  Reset_Handler
    Reset_Handler
                    LDR     R0, =Stack_Top
                    MOV     SP, R0
                    IMPORT  __main
                    LDR     R0, =__main
                    BX      R0
                    EXPORT  main
    main
    ; Your code
                    AREA |.data|, DATA, READWRITE
                    ALIGN
    foo             DCD 1,2,3,4,5,6
                    END
