Scatter file for segmenting the MCU flash
I am using Keil for development with my FRDM-LKL03Z board. It has the PKL03Z32VFK4 on-board.
I would like to segment the flash memory into 3 parts:
1. For storing application(user) data.
2. For storing incoming FW binary for FOTA update.
3. For a custom bootloader.
4. For the running code.
Could you please help me with a template scatter file with these 4 segments defined? I will then modify the bounds of each section to suit my needs.
Thanks very much!
  • If you enter two separte flash address ranges using the IDE, then the IDE can generate a scatter file with two regions. Then follow the pattern and add two more regions.
  • You'd want to create this as multiple projects, defining the region used by each and not allowing the linker to overlap them. Unless you have a lot of skill, I wouldn't tackle this as a single scatter file for all the above listed uses.
    You can use the IROMx areas in the Target configuration to create multiple LOAD REGIONS
  • I think they have to co-exist as one project. Only the application and bootloader can be different projects but the other two have to co-exist, at-least with the application code.
  • The application data doesn't need a separate partition, unless you have some logic to reconfiguring individual data values.
    So one region for boot loader.
    One region for application.
    And maybe a third region for a downloaded copy. But this doesn't need to be a separate region in the Scatter file unless you plan to build your application in two versions for running at 2 different load addresses.
    If all you need is a region for temporary storage of a new application, then it's enough to use the settings in the dialog to "hide" a large enough part of the flash. Then the application can use direct IAP commands to store the downloaded binary to this region. And then set a flag and reboot to request the boot loader to copy the fully retrieved new application image into the normal application flash region.
    But as noted - boot loader and application should be built as individual projects or at least as individual targets, to make sure they are independent.
