Using External SDRAM K4S56161632 as Default Memory for a LPC1788
I want to store the variables of my code in the External SDRAM,So I've made these change to Target tab of Options window :
1. Default box for off-chip RAM1 is checked (Base Address: 0xA0000000 Size:0x10000000
2. Default box for on-chip IRAM1 is unchecked
(both with unchecked No Init checkbox)
Also, I’ve edited the startup_LPC177x_8x in this order:
Reset_Handler PROC
              EXPORT  Reset_Handler   [WEAK]
              IMPORT  SystemInit
              IMPORT  SDRAMInit
              IMPORT  __main
              LDR    R0, =SystemInit
              BLX    R0
              LDR    R0, =SDRAMInit
              BLX    R0
              LDR    R0, =__main
              BLX    R0
              ENDP
But when I debug, as you can see in picture above, program line stops at ‘SystemInit’ line
Please notice that when Internal Memory is selected as default, there is no problem with accessing to Ext SDRAM in main.c code and it’s possible to read & write from SDRAM correctly. (for example, I checked the address 0xA0000001)
I want my MCU to be Initialized with Ext SDRAM or at best with both of them (Internal & External) but it’s not possible yet.
Do I have to change the SystemInit config?
How can I solve this issue?
Thanks In Advance
  • Without knowing the specifics of your processor - have you initialized the external memory controller before your program needs to make the first RAM accesses?
  • Sorry not seeing a picture or link to one. Code related to the screen shot is also not provided.
    Normally you'd initialize external memory and buses in SystemInit() or functions called by it. You must remember however that at this point no statics have or can be initialized, so your C code needs to very simple and not rely on RAM initialized variables.
    If it is fouling up in SystemInit() it suggests it is expecting something you haven't supplied, DEBUG IT
  • In main.c code I’ve included the "sdram_k4s561632j.h" header file and in int main() function, exactly also after defining some volatile variables, I’ve use SDRAMInit();
    Also in startup_LPC177x_8x.s , as I mentioned before , I’ve added these lines to the code:
    IMPORT  SDRAMInit
    LDR    R0, =SDRAMInit
    BLX    R0
    Do you I need add something else to my code, for Initializing EMC?
    lpc177x_8x_emc.c exist in my project , without any error.
    Thanks Per Westermark
  • Westonsupermare, Sorry for the image.
    Please refer to the reply I've posted for Westermark.
    I debugged my code and as I said it stops at this line in startup_LPC177x_8x.s :
    LDR    R0, =SystemInit
    and also I can't proceed to debug because the buttons for accessing the inside of function is not active when debugging stops at that line.
    I don't know whgat is the problem with that line.
    Thank you
  • You should be able step, and step-in from the disassembly view.
    If you can't perhaps you'd want to disassemble the app fully and walk the code manually.
    I would not replace IRAM, it works without any initialization, I'd put the heap into the SDRAM and allocate it from there, or use a scatter file and assembler directives or pragmas to direct specific static allocations into it.
    Consider wth you are putting the stack!! You can't put the stack in the SDRAM during start-up, it simply isn't working yet, and it is probably SLOWER than IRAM
