I'd like to ask for solution to let the microcontroller (MCU) get data from ALS (ambient light sensor).I'm wondering why my MCU can't get ACK (acknowledge signal) low? In this program I have 2 functions: ALS_config() is to send command from MCU to modify settings in the ALS. MCU_read() is to let MCU read lux data from ALS.
Currently, ALS_config() can get ACK = 0 after the data byte was sent. It means that it works well. But MCU_read() function get ACK = 1, means no acknowledge signal. I think that my program is in the right form compare with the conventional I2C protocol. www.robot-electronics.co.uk/i2c-tutorial
Please help me point out the wrong part in my code.
void main(void) { MCU_Initial(); Initial_Variable(); delay1m(500); //Wait FPGA Ready FPGA_TEST(); delay1m(5); while(1) { RS232Control(); ALS_to_MCU(); if(flagstep==1 || flagstep_down==1) { Main_Pattern(); } } } void I2C_START(void) { delay1m(6); ACK_f = 0; I2C_SDA = 1; delay1m(2); I2C_SCL = 1; delay1m(8); I2C_SDA = 0; delay1m(5); I2C_SCL = 0; delay1m(5); } //======================================================================================= // I2C_1 Ack (EEPROM) //======================================================================================= void I2C_ACK(void) { delay1m(3); I2C_SDA = 1; delay1m(1); I2C_SCL = 1; delay1m(3); if(!I2C_SDA) ACK_f = 1; delay1m(2); I2C_SCL = 0; delay1m(1); I2C_SDA = 0; delay1m(5); } void I2C_NAK() { I2C_SDA = 1; I2C_SCL = 1; delay1m(1); I2C_SCL = 0; I2C_SDA = 1; } //======================================================================================= // I2C_1 Stop (EEPROM) //======================================================================================= void I2C_STOP(void) { I2C_SCL = 0; I2C_SDA = 0; delay1m(8); I2C_SCL = 1; delay1m(2); I2C_SDA = 1; } void I2C_RESET(void) { unsigned char x; I2C_START(); for(x=0x00;x<=0x09;x++) //EEPROM restart 9 times is avoided unexpected state { I2C_SDA = 1; I2C_SCL = 0; delay1m(2); I2C_SCL = 1; delay1m(2); } I2C_START(); I2C_STOP(); delay1m(2); } //======================================================================================= void I2C_TX(unsigned char Tx_data) { unsigned char x; for(x=0;x<8;x++) { I2C_SCL = 0; delay1m(1); if(Tx_data & 0x80) I2C_SDA = 1; else I2C_SDA = 0; Tx_data <<= 1; delay1m(1); I2C_SCL = 1; delay1m(2); } I2C_SCL = 0; } //======================================================================================= unsigned char I2C_RX(void) { unsigned char x; I2C_SDA = 1; delay1m(2); for(x=0;x<8;x++) { I2C_rx_buf <<= 1; I2C_SCL = 1; delay1m(1); if(I2C_SDA) I2C_rx_buf |= 0x01; else I2C_rx_buf &= 0xfe; delay1m(2); I2C_SCL = 0; delay1m(3); } return I2C_rx_buf; delay1m(2); } ///// Configuration register /////////// void ALS_config(unsigned char slave_write,unsigned char dataA,unsigned char dataB) { I2C_START(); I2C_TX(slave_write); I2C_ACK(); I2C_TX(0x01); I2C_ACK(); I2C_TX(dataA); // I2C_RX(); I2C_ACK(); I2C_TX(dataB); // I2C_RX(); I2C_ACK(); I2C_STOP(); } void MCU_read(unsigned char slave_write,unsigned char slave_read) { unsigned char i, ALS_MSB, ALS_LSB; unsigned int ALS_lux; ////// Partial write //////// I2C_START(); I2C_TX(slave_write); I2C_ACK(); I2C_TX(0x00); I2C_ACK(); // I2C_STOP(); //////////////// Read from ALS ///////////////////////////// I2C_START(); I2C_TX(slave_read); I2C_ACK(); I2C_RX(); ALS_LSB = I2C_rx_buf; ALS_MSB = I2C_rx_buf<<8; I2C_ACK(); /* This part doesn't work. So I marked it. I2C_SDA = 0; delay1m(1); I2C_SCL = 1; delay1m(1); I2C_SCL = 0; delay1m(1); I2C_SDA = 0; */ delay1m(1); I2C_RX(); ALS_MSB = I2C_rx_buf; I2C_ACK(); // I2C_NAK(); I2C_STOP(); ALS_lux = ALS_MSB | ALS_LSB; } // MCU read data from ALS ////////////////////////////////// //void ALS_to_MCU(unsigned char slave_write,unsigned char slave_read,unsigned char dataA,unsigned char dataB) void ALS_to_MCU(void) { ALS_config(0x88,0xC4,0x10); MCU_read(0x88,0x89); }
which 8051?
A mass. You tried to start another transaction while current in process. Also I don't know why you generate a NACK... to whom? You wanna ALS to ACK your NACK?
And I suggest you to combine ACK/NACK in each TX()/RX() function.
