I have a following statement in C which I use in C51 on intel 8052 micros, without any errors. But while using ARM M0- M3 processors i get an warning message for the same.. **** int *x; x = 0xFC82; *x = 0xAB; warning: incompatible integer to pointer conversion assigning to "int *" from " int". What is the reason ? and what is the correct statement(s) ? Appreciate any explanation.. Thanks. Bhal
www.avrfreaks.net/.../2210116
