I want to use a free GCC compiler. I have downloaded gcc-arm-none-eabi 5.4 V. Then I set in Project>Manage>Project items>Folder/Extensions and there I check the Use GCC Compiler (GNU) for ARM projects. PRefix is: arm-none-eabi- and Folder is C:\Program Files (x86)\GNU Tools ARM Embedded\5.4 2016q3\bin\
Then I tried to compile do project but with error: --- Error: failed to execute 'arm-none-eabi-gcc'
What I did a wrong? Did I forget for anything?
Thank you.
P.S. The project runs correctly with standard keil compiler...
Folder should be C:\Program Files (x86)\GNU Tools ARM Embedded\5.4 2016q3\
not Folder is C:\Program Files (x86)\GNU Tools ARM Embedded\5.4 2016q3\bin\
... i get/got the same error message:
Rebuild target 'STM32F407 RAM' assembling STM32F40xxx_41xxx_OPT.s... --- Error: failed to execute 'arm-none-eabias' ".\Blinky.elf" - 1 Error(s), 0 Warning(s). Target not created. Build Time Elapsed: 00:00:00
The window items in "Manage Project Items" are: Use GCC Compiler (GNU) for ARM projects Prefix: arm-none-eabi Folder: C:\Program Files (x86)\GNU Tools ARM Embedded\7 2017-q4-major\
Toolbox installed from: developer.arm.com/.../downloads " Windows 32-bit File: gcc-arm-none-eabi-7-2018-q2-update-win32.exe (82.98 MB)" on a 64bit Windows 10 (1709).
Command-Window-trial:
C:\Program Files (x86)\GNU Tools ARM Embedded\7 2017-q4-major>arm-none-eabi-gcc c:\work\Blinky_5.24.2.0_probier\Blinky.c c:\work\Blinky_5.24.2.0_probier\Blinky.c:15:77: fatal error: stm32f4xx_hal.h: No such file or directory #include "stm32f4xx_hal.h" // Keil::Device:STM32Cube HAL:Common ^ compilation terminated.
For any help many thanks in advance, Roland (newbie)
