getting mass storage example to work using J-link
HI
I am completely new to keil MCB 4300 !!
im trying to run the USB Host Mass Storage example using j link . but nothing is shown in my debug(printf) viewer !! i tried couple of solutions like this link :
www.keil.com/.../jlink_trace_itm_viewer.htm
but i get the error that says : stdin stdout multiply defined .........
can anyone help me please ?
  • You need a #pragma to stop in including library stuff in the linker,
    /* Implementation of putchar (also used by printf function to output data)    */
    int SendChar(int ch)                    /* Write character to Serial Port     */
            ITM_SendChar(ch); // From core_cm4.c
      return(ch);
    #include <rt_misc.h>
    #pragma import(__use_no_semihosting_swi)
    struct __FILE { int handle; /* Add whatever you need here */ };
    FILE __stdout;
    int fputc (int ch, FILE *f) { return (SendChar(ch)); }
    int ferror (FILE *f) {
      /* Your implementation of ferror */
      return EOF;
    void _ttywrch (int ch) { SendChar(ch); }
    void _sys_exit (int return_code) { for (;;); }
    You'll need to #include <stdio.h> and make sure you have the trace clock matching the system clock. There are other retargeting examples, you might want to check those and the documentation.
  • Sorry to ask this question !!
    where should i add this code ? i added the code to mssstorage.c and i got one warning and one error!!
    warning : implicit declaration of function itm_sendchar is not valid in c99.
    error :.\Output\MassStorage.axf: Error: L6200E: Symbol __stdout multiply defined (by stdio_streams.o and massstorage.o).
    could you please help me ?
